Ga door naar hoofdinhoud
ILVE Microwave Replacement Bulb Replacement
Wat je nodig hebt
    1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: stap 1, afbeelding 1 van 1
      • Remove the brown plug.
      • The screw attaching the microwave is below
      Vraag FixBot
      Voeg opmerking toe
    2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: stap 2, afbeelding 1 van 2 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: stap 2, afbeelding 2 van 2
      • Remove the cross point screws from the outer case back
      • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
      • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
      Vraag FixBot
      Voeg opmerking toe
    3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: stap 3, afbeelding 1 van 1
      • The socket is on top right side of the microwave
      • Remove the plugs
      • Bend up the metal clips, and pull out the socket
      Vraag FixBot
      Voeg opmerking toe
    4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: stap 4, afbeelding 1 van 2 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: stap 4, afbeelding 2 van 2
      • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
      • The glue goes all the way down the thread so remove as much as you can see.
      • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
      Vraag FixBot
      Voeg opmerking toe
    5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: stap 5, afbeelding 1 van 1
      • When you re assemble the outer case make sure the tabs on the front go either side of the front.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Martin Hampton
1.350 Reputatie
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 61
Altijd: 4,496
