Ga door naar hoofdinhoud
IBM WorkPad c3 Motherboard Replacement
Wat je nodig hebt
    1. IBM WorkPad c3 Motherboard Replacement, Back Case: stap 1, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement, Back Case: stap 1, afbeelding 2 van 2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM WorkPad c3 Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM WorkPad c3 Motherboard Replacement: stap 3, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      Vraag FixBot
      Voeg opmerking toe
    1. IBM WorkPad c3 Motherboard Replacement, Front Case: stap 4, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement, Front Case: stap 4, afbeelding 2 van 2
      • Turn the device over, so that the screen is laying on a flat surface.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM WorkPad c3 Motherboard Replacement: stap 5, afbeelding 1 van 3 IBM WorkPad c3 Motherboard Replacement: stap 5, afbeelding 2 van 3 IBM WorkPad c3 Motherboard Replacement: stap 5, afbeelding 3 van 3
      • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
      • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
      • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM WorkPad c3 Motherboard Replacement: stap 6, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement: stap 6, afbeelding 2 van 2
      • The device will be extremely hot. Use a towel or oven mitt to grab it.
      • Using the Plastic Opening Tools, take the front of the case off.
      • If the case is difficult to remove, try repeating step 2.
      • The power button at the top of the device will be loose once the front part of the case is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. IBM WorkPad c3 Motherboard Replacement, Battery: stap 7, afbeelding 1 van 1
      • Remove the yellow tape that is covering the battery connector
      Vraag FixBot
      Voeg opmerking toe
    2. IBM WorkPad c3 Motherboard Replacement: stap 8, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using the tweezers, carefully disconnect the battery cable from the port
      Vraag FixBot
      Voeg opmerking toe
    3. IBM WorkPad c3 Motherboard Replacement: stap 9, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement: stap 9, afbeelding 2 van 2
      • Using the plastic opening tools, lift the battery out of the case
      • The battery is secured with adhesive and it will take some effort to remove
      Vraag FixBot
      Voeg opmerking toe
    1. IBM WorkPad c3 Motherboard Replacement, LCD: stap 10, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement, LCD: stap 10, afbeelding 2 van 2
      • Using the spudger lift the tabs holding the LCD/Digitizer combo cables to the WorkPad.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM WorkPad c3 Motherboard Replacement: stap 11, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement: stap 11, afbeelding 2 van 2
      • Using your thumb, press down gently on the back of the LCD.
      • The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
      Vraag FixBot
      Voeg opmerking toe
    1. IBM WorkPad c3 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
      • Using the plastic opening tool, lift the clip holding the motherboard cable.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM WorkPad c3 Motherboard Replacement: stap 13, afbeelding 1 van 2 IBM WorkPad c3 Motherboard Replacement: stap 13, afbeelding 2 van 2
      • Gripping the motherboard as shown, lift up slightly and pull outward.
      • Small plastic tabs hold the motherboard down. Lifting too hard will break these off, and the motherboard will be loose upon replacement.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Emily Falkenstein
75 Reputatie
5 handleidingen geschreven
Cal Poly, Team 21-35, Regan Fall 2010 Lid van Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 2,422
