Ga door naar hoofdinhoud
IBM Thinkpad T60 Touchpad Replacement
Wat je nodig hebt
  1. IBM Thinkpad T60 Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. IBM Thinkpad T60 Touchpad Replacement: stap 2, afbeelding 1 van 2 IBM Thinkpad T60 Touchpad Replacement: stap 2, afbeelding 2 van 2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    Vraag FixBot
    Voeg opmerking toe
  3. IBM Thinkpad T60 Touchpad Replacement, Palm Rest: stap 3, afbeelding 1 van 2 IBM Thinkpad T60 Touchpad Replacement, Palm Rest: stap 3, afbeelding 2 van 2
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  4. IBM Thinkpad T60 Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
    Vraag FixBot
    Voeg opmerking toe
  5. IBM Thinkpad T60 Touchpad Replacement: stap 5, afbeelding 1 van 2 IBM Thinkpad T60 Touchpad Replacement: stap 5, afbeelding 2 van 2
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
    • Detach the connector by pulling upwards on the white tab.
    Vraag FixBot
    Voeg opmerking toe
  6. IBM Thinkpad T60 Touchpad Replacement, Touchpad: stap 6, afbeelding 1 van 1
    • Turn the palm rest over to access the back of the touch pad.
    Vraag FixBot
    Voeg opmerking toe
  7. IBM Thinkpad T60 Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Using your fingers, remove the plastic film that covers the two connectors to the touchpad.
    Vraag FixBot
    Voeg opmerking toe
  8. IBM Thinkpad T60 Touchpad Replacement: stap 8, afbeelding 1 van 3 IBM Thinkpad T60 Touchpad Replacement: stap 8, afbeelding 2 van 3 IBM Thinkpad T60 Touchpad Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Identify the connector with the black cables.
    • In order to disengage the connector, use tweezers to pull out on the two grey tabs
    • Once the grey tabs have been disengaged, use tweezers to pull on the black cables and the connector will detach from the port.
    Vraag FixBot
    Voeg opmerking toe
  9. IBM Thinkpad T60 Touchpad Replacement: stap 9, afbeelding 1 van 2 IBM Thinkpad T60 Touchpad Replacement: stap 9, afbeelding 2 van 2
    • Identify the connector with the orange cables.
    • In order to disengage the connector use tweezers to pull the orange cable outward.
    Vraag FixBot
    Voeg opmerking toe
  10. IBM Thinkpad T60 Touchpad Replacement: stap 10, afbeelding 1 van 2 IBM Thinkpad T60 Touchpad Replacement: stap 10, afbeelding 2 van 2
    • Use a #0 Phillips screwdriver to unscrew the four 3.4 mm screws circled in red.
    Vraag FixBot
    Voeg opmerking toe
  11. IBM Thinkpad T60 Touchpad Replacement: stap 11, afbeelding 1 van 1
    • Using your fingers, remove the metal framing surrounding the touch pad by pulling upwards on each of the four corners.
    Vraag FixBot
    Voeg opmerking toe
  12. IBM Thinkpad T60 Touchpad Replacement: stap 12, afbeelding 1 van 1
    • Remove the touch pad by lifting it out of the palm rest with your fingers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dylan Kratochvil
663 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-9, Maness Winter 2013 Lid van Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Leden
16 handleidingen geschreven
2Gids Commentaar
I bought mine used on eBay. and upgraded the HDD and RAM and it is working perfectly. But I recently noticed that the palm rest is not perfectly seated at the front edge and is raised by roughly 2mm. (⅛in.) I have tried refitting the palm rest, but it hasn’t made any different. It is possible that it was like that before I fitted the RAM and I just hadn’t notice, so it could be the result of an earlier intervention. The machine still works OK and the lid closes, so it isn’t a big deal, but it is a bit annoying that such a well engineered device doesn’t go back together exactly as it should. Any suggestions?
Mike Kearney - Antwoord Deel
Sort of solved it . . . . . Get the left hand side located first and jiggle it about a bit and the palm rest will fit back neatly. But it isn’t immediately obvious how you shouls go about this.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 46
Altijd: 4,375
