Ga door naar hoofdinhoud
IBM ThinkPad T42 RAM Replacement
Wat je nodig hebt
  1. IBM ThinkPad T42 RAM Replacement, Battery Clips: stap 1, afbeelding 1 van 1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
    Vraag FixBot
    Voeg opmerking toe
  2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: stap 2, afbeelding 1 van 1
    • Carefully grab the battery, then pull it straight out, not at an angle.
    Vraag FixBot
    Voeg opmerking toe
  3. IBM ThinkPad T42 RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Unscrew the pictured screwed holding the memory cover in place.
    Vraag FixBot
    Voeg opmerking toe
  4. IBM ThinkPad T42 RAM Replacement: stap 4, afbeelding 1 van 1
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
    • Pull the stick out carefully.
    • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Kevin Rehm
472 Reputatie
4 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
37 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 7,548
