Ga door naar hoofdinhoud
IBM ThinkPad T41 Motherboard Replacement
Wat je nodig hebt
  1. IBM ThinkPad T41 Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    Vraag FixBot
    Voeg opmerking toe
  2. IBM ThinkPad T41 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    Vraag FixBot
    Voeg opmerking toe
  3. IBM ThinkPad T41 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    Vraag FixBot
    Voeg opmerking toe
  4. IBM ThinkPad T41 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  5. IBM ThinkPad T41 Motherboard Replacement, Trackpad: stap 5, afbeelding 1 van 1
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
    Vraag FixBot
    Voeg opmerking toe
  6. IBM ThinkPad T41 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the five screws that were hidden by the stickers.
    Vraag FixBot
    Voeg opmerking toe
  7. IBM ThinkPad T41 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
    Vraag FixBot
    Voeg opmerking toe
  8. IBM ThinkPad T41 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
    Vraag FixBot
    Voeg opmerking toe
  9. IBM ThinkPad T41 Motherboard Replacement, RAM: stap 9, afbeelding 1 van 1
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
    Vraag FixBot
    Voeg opmerking toe
  10. IBM ThinkPad T41 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift out the RAM chip.
    Vraag FixBot
    Voeg opmerking toe
  11. IBM ThinkPad T41 Motherboard Replacement, Wireless Network Card: stap 11, afbeelding 1 van 1
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
    Vraag FixBot
    Voeg opmerking toe
  12. IBM ThinkPad T41 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
    Vraag FixBot
    Voeg opmerking toe
  13. IBM ThinkPad T41 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Pull the wireless network card out.
    Vraag FixBot
    Voeg opmerking toe
  14. IBM ThinkPad T41 Motherboard Replacement, CMOS Battery: stap 14, afbeelding 1 van 1
    • Lift the yellow plastic-covered battery up.
    Vraag FixBot
    Voeg opmerking toe
  15. IBM ThinkPad T41 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Unplug the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  16. IBM ThinkPad T41 Motherboard Replacement, Speakers: stap 16, afbeelding 1 van 1
    • Lift the speakers out by starting with the left end and then unsnake the wires.
    Vraag FixBot
    Voeg opmerking toe
  17. IBM ThinkPad T41 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Unplug the wires from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  18. IBM ThinkPad T41 Motherboard Replacement, Expansion Slot: stap 18, afbeelding 1 van 1
    • Remove the screw on the left hand side of the case, above the expansion slot.
    Vraag FixBot
    Voeg opmerking toe
  19. IBM ThinkPad T41 Motherboard Replacement: stap 19, afbeelding 1 van 2 IBM ThinkPad T41 Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Lift the black plastic border by lifting on either side.
    • Once the sides are up, pull the border towards you and away from the screen.
    • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
    Vraag FixBot
    Voeg opmerking toe
  20. IBM ThinkPad T41 Motherboard Replacement: stap 20, afbeelding 1 van 1
    • Pull the sheet metal cover away from slot.
    Vraag FixBot
    Voeg opmerking toe
  21. IBM ThinkPad T41 Motherboard Replacement: stap 21, afbeelding 1 van 1
    • Lift out the expansion slot by starting at the entrance hole and pulling upward.
    • Note: Try wiggling the slot from side to side until it comes out all the way.
    Vraag FixBot
    Voeg opmerking toe
  22. IBM ThinkPad T41 Motherboard Replacement, Modem: stap 22, afbeelding 1 van 1
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  23. IBM ThinkPad T41 Motherboard Replacement: stap 23, afbeelding 1 van 1
    • Lift the modem up, unplugging it from the motherboard as you lift.
    Vraag FixBot
    Voeg opmerking toe
  24. IBM ThinkPad T41 Motherboard Replacement: stap 24, afbeelding 1 van 2 IBM ThinkPad T41 Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
    Vraag FixBot
    Voeg opmerking toe
  25. IBM ThinkPad T41 Motherboard Replacement, Screen: stap 25, afbeelding 1 van 1
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
    Vraag FixBot
    Voeg opmerking toe
  26. IBM ThinkPad T41 Motherboard Replacement: stap 26, afbeelding 1 van 1
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
    Vraag FixBot
    Voeg opmerking toe
  27. IBM ThinkPad T41 Motherboard Replacement: stap 27, afbeelding 1 van 1
    • Remove a single screw from the metal plate that secures the display cable.
    Vraag FixBot
    Voeg opmerking toe
  28. IBM ThinkPad T41 Motherboard Replacement: stap 28, afbeelding 1 van 1
    • Pull the metal plate away from the display cable.
    Vraag FixBot
    Voeg opmerking toe
  29. IBM ThinkPad T41 Motherboard Replacement: stap 29, afbeelding 1 van 1
    • Disconnect the display cable.
    Vraag FixBot
    Voeg opmerking toe
  30. IBM ThinkPad T41 Motherboard Replacement: stap 30, afbeelding 1 van 1
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
    Vraag FixBot
    Voeg opmerking toe
  31. IBM ThinkPad T41 Motherboard Replacement: stap 31, afbeelding 1 van 1
    • Lift out the screen.
    Vraag FixBot
    Voeg opmerking toe
  32. IBM ThinkPad T41 Motherboard Replacement, Fan: stap 32, afbeelding 1 van 1
    • Unsnake the black cable from the black plastic frame.
    Vraag FixBot
    Voeg opmerking toe
  33. IBM ThinkPad T41 Motherboard Replacement: stap 33, afbeelding 1 van 1
    • Remove the sheet metal piece, which was underneath the modem.
    Vraag FixBot
    Voeg opmerking toe
  34. IBM ThinkPad T41 Motherboard Replacement: stap 34, afbeelding 1 van 1
    • Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
    Vraag FixBot
    Voeg opmerking toe
  35. IBM ThinkPad T41 Motherboard Replacement: stap 35, afbeelding 1 van 1
    • Lift away the gray metal frame.
    Vraag FixBot
    Voeg opmerking toe
  36. IBM ThinkPad T41 Motherboard Replacement: stap 36, afbeelding 1 van 1
    • Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
    • Remove three other screws on the other side of the covers.
    • You should have six screws in total, three of one size and three of another size.
    Vraag FixBot
    Voeg opmerking toe
  37. IBM ThinkPad T41 Motherboard Replacement: stap 37, afbeelding 1 van 1
    • Lift out the optical bay and HDD covers.
    Vraag FixBot
    Voeg opmerking toe
  38. IBM ThinkPad T41 Motherboard Replacement: stap 38, afbeelding 1 van 1
    • Lift out the black plastic frame.
    Vraag FixBot
    Voeg opmerking toe
  39. IBM ThinkPad T41 Motherboard Replacement: stap 39, afbeelding 1 van 1
    • Unplug the fan from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  40. IBM ThinkPad T41 Motherboard Replacement: stap 40, afbeelding 1 van 1
    • Remove the three screws on the fan.
    Vraag FixBot
    Voeg opmerking toe
  41. IBM ThinkPad T41 Motherboard Replacement: stap 41, afbeelding 1 van 1
    • Lift the fan out.
    Vraag FixBot
    Voeg opmerking toe
  42. IBM ThinkPad T41 Motherboard Replacement, CPU: stap 42, afbeelding 1 van 1
    • Turn the CPU retaining screw 90 degrees counterclockwise.
    • Carefully pull the CPU out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  43. IBM ThinkPad T41 Motherboard Replacement, Motherboard: stap 43, afbeelding 1 van 1
    • Remove the two screws in the upper right corner that secure the gray metal frame.
    Vraag FixBot
    Voeg opmerking toe
  44. IBM ThinkPad T41 Motherboard Replacement: stap 44, afbeelding 1 van 1
    • Unplug the small ribbon cable attached to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  45. IBM ThinkPad T41 Motherboard Replacement: stap 45, afbeelding 1 van 1
    • Remove the single screw located next to the USB slots.
    Vraag FixBot
    Voeg opmerking toe
  46. IBM ThinkPad T41 Motherboard Replacement: stap 46, afbeelding 1 van 1
    • Rotate the device so that the front faces you.
    • Lift the entire motherboard assembly out of the case.
    Vraag FixBot
    Voeg opmerking toe
  47. IBM ThinkPad T41 Motherboard Replacement: stap 47, afbeelding 1 van 1
    • Disconnect the power connector from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  48. IBM ThinkPad T41 Motherboard Replacement: stap 48, afbeelding 1 van 1
    • Using a nut driver or a pair of thin nose pliers, remove the two stand off screws next to the pink parallel port on the back of the computer.
    Vraag FixBot
    Voeg opmerking toe
  49. IBM ThinkPad T41 Motherboard Replacement: stap 49, afbeelding 1 van 1
    • Lift up the outer end of the grey metal frame.
    • Carefully rotate the frame clockwise to release it from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
20 andere personen hebben deze handleiding voltooid.
Marissa Blustein
543 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-8, Maness Spring 2010 Lid van Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Leden
29 handleidingen geschreven
6Gids Commentaar
Hello,
Thanks for this !
When assembling again, I noticed that at the contact between the micro-processor and the cooler the thermal paste there was a very small amount of thermal paste.
I had none to add, therefore I reassembled as is.
After starting the machine again I note that the cooling fan never stops.
I suggest that at reassembling should thermal paste added.
Philippe - Antwoord Deel
ibm thinkpad t42 laptop driver are not download please sir my laptop motherboard information send in my email id . how can download driver download for ibm laptop
Himanshu Kumar - Antwoord Deel
Excellent tutorial. Thank you.
genese_cranford - Antwoord Deel
thanks alot!
Geburtswehe - Antwoord Deel
It’s tempting to try, but I’d feel much braver with a reassembly tutorial!
Christine Segatti - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 86
Altijd: 51,251
