Ga door naar hoofdinhoud
IBM ThinkPad T41 Keyboard Replacement
Wat je nodig hebt
    1. IBM ThinkPad T41 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM ThinkPad T41 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM ThinkPad T41 Keyboard Replacement: stap 3, afbeelding 1 van 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Vraag FixBot
      Voeg opmerking toe
    4. IBM ThinkPad T41 Keyboard Replacement: stap 4, afbeelding 1 van 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Marissa Blustein
543 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-8, Maness Spring 2010 Lid van Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Leden
78 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 57
Altijd: 9,144
