Ga door naar hoofdinhoud
IBM ThinkPad T30 Hard Drive Replacement
Wat je nodig hebt
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
    Vraag FixBot
    Voeg opmerking toe
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. IBM ThinkPad T30 Hard Drive Replacement: stap 3, afbeelding 1 van 3 IBM ThinkPad T30 Hard Drive Replacement: stap 3, afbeelding 2 van 3 IBM ThinkPad T30 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
    Vraag FixBot
    Voeg opmerking toe
  4. IBM ThinkPad T30 Hard Drive Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T30 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  5. IBM ThinkPad T30 Hard Drive Replacement: stap 5, afbeelding 1 van 2 IBM ThinkPad T30 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 andere personen hebben deze handleiding voltooid.
Allie Knauer
90 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-20, Amido Fall 2012 Lid van Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Leden
17 handleidingen geschreven
1Gids Commentaar
good description and photos..thanks :]
David - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 93
Altijd: 20,704
