Ga door naar hoofdinhoud
IBM ThinkPad R40 Keyboard Keys Replacement
Wat je nodig hebt
    1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: stap 1, afbeelding 1 van 1
      • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: stap 2, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: stap 3, afbeelding 1 van 1
      • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
      Vraag FixBot
      Voeg opmerking toe
    4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: stap 4, afbeelding 1 van 1
      • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: stap 5, afbeelding 1 van 1
      • After lining the key up, the black and white pieces will line up.
      Vraag FixBot
      Voeg opmerking toe
    6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: stap 6, afbeelding 1 van 1
      • Step 6: The key should not be firmly locked into place and functioning normally.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erin
231 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 45
Altijd: 5,303
