Ga door naar hoofdinhoud
IBM ThinkPad A30 Fan Replacement
Wat je nodig hebt
    1. IBM ThinkPad A30 Fan Replacement, Battery: stap 1, afbeelding 1 van 2 IBM ThinkPad A30 Fan Replacement, Battery: stap 1, afbeelding 2 van 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. IBM ThinkPad A30 Fan Replacement, Upper Case: stap 2, afbeelding 1 van 1
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM ThinkPad A30 Fan Replacement: stap 3, afbeelding 1 van 1
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM ThinkPad A30 Fan Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad A30 Fan Replacement: stap 4, afbeelding 2 van 2
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. IBM ThinkPad A30 Fan Replacement: stap 5, afbeelding 1 van 3 IBM ThinkPad A30 Fan Replacement: stap 5, afbeelding 2 van 3 IBM ThinkPad A30 Fan Replacement: stap 5, afbeelding 3 van 3
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
      Vraag FixBot
      Voeg opmerking toe
    5. IBM ThinkPad A30 Fan Replacement: stap 6, afbeelding 1 van 3 IBM ThinkPad A30 Fan Replacement: stap 6, afbeelding 2 van 3 IBM ThinkPad A30 Fan Replacement: stap 6, afbeelding 3 van 3
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
      Vraag FixBot
      Voeg opmerking toe
    6. IBM ThinkPad A30 Fan Replacement: stap 7, afbeelding 1 van 2 IBM ThinkPad A30 Fan Replacement: stap 7, afbeelding 2 van 2
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
      Vraag FixBot
      Voeg opmerking toe
    7. IBM ThinkPad A30 Fan Replacement: stap 8, afbeelding 1 van 3 IBM ThinkPad A30 Fan Replacement: stap 8, afbeelding 2 van 3 IBM ThinkPad A30 Fan Replacement: stap 8, afbeelding 3 van 3
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
      Vraag FixBot
      Voeg opmerking toe
    1. IBM ThinkPad A30 Fan Replacement, Display Assembly: stap 9, afbeelding 1 van 1
      • Remove the 5.6mm screw that holds the LCD to the upper case.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM ThinkPad A30 Fan Replacement: stap 10, afbeelding 1 van 3 IBM ThinkPad A30 Fan Replacement: stap 10, afbeelding 2 van 3 IBM ThinkPad A30 Fan Replacement: stap 10, afbeelding 3 van 3
      • Remove the 5.6mm screw on the left side of the three-pronged connector.
      • Remove the other two 16.7mm screws.
      • Lift and remove connector.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM ThinkPad A30 Fan Replacement: stap 11, afbeelding 1 van 2 IBM ThinkPad A30 Fan Replacement: stap 11, afbeelding 2 van 2
      • Pull out the white tab connecting the LCD to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. IBM ThinkPad A30 Fan Replacement: stap 12, afbeelding 1 van 2 IBM ThinkPad A30 Fan Replacement: stap 12, afbeelding 2 van 2
      • Turn the laptop so that the back is facing you.
      • Remove the four 5.6mm long screws.
      Vraag FixBot
      Voeg opmerking toe
    5. IBM ThinkPad A30 Fan Replacement: stap 13, afbeelding 1 van 3 IBM ThinkPad A30 Fan Replacement: stap 13, afbeelding 2 van 3 IBM ThinkPad A30 Fan Replacement: stap 13, afbeelding 3 van 3
      • Place the laptop so that the LCD is facing you again.
      • Gently lift the LCD monitor up and out.
      • Remove the black plastic tab.
      Vraag FixBot
      Voeg opmerking toe
    1. IBM ThinkPad A30 Fan Replacement, Fan: stap 14, afbeelding 1 van 1
      • Remove the following screws from the fan retention bracket:
      • Single 5.6 mm screw.
      • Three 16.1 mm screws.
      Vraag FixBot
      Voeg opmerking toe
    2. IBM ThinkPad A30 Fan Replacement: stap 15, afbeelding 1 van 1
      • Lift the heatsink bracket up.
      Vraag FixBot
      Voeg opmerking toe
    3. IBM ThinkPad A30 Fan Replacement: stap 16, afbeelding 1 van 3 IBM ThinkPad A30 Fan Replacement: stap 16, afbeelding 2 van 3 IBM ThinkPad A30 Fan Replacement: stap 16, afbeelding 3 van 3
      • Be careful not to pull too hard. There is a cable attached to the fan.
      • Lift the fan/heatsink assembly up.
      • Locate the fan power cable and pull upwards near the connector.
      • Remove the fan/heatsink assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jessica
162 Reputatie
7 handleidingen geschreven
Cal Poly, Team 4-44, Amido Fall 2010 Lid van Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Leden
77 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 42
Altijd: 3,155
