Inleiding
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
Wat je nodig hebt
Slide the battery release latch to the right.
Pull out the battery out towards the front of the device.
Remove the plastic screw covers, then remove the 3 Phillips screws under them.
Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
