Ga door naar hoofdinhoud
Humax RM-H01U Remote Disassembly
Wat je nodig hebt
    1. Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: stap 1, afbeelding 1 van 2 Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: stap 1, afbeelding 2 van 2
      • The remote has a bottom and top part. They are held together with plastic clips.
      • Don't forget to remove the battery, just for good measure.
      Vraag FixBot
      Voeg opmerking toe
    2. Humax RM-H01U Remote Disassembly, Opening using a spudger: stap 2, afbeelding 1 van 3 Humax RM-H01U Remote Disassembly, Opening using a spudger: stap 2, afbeelding 2 van 3 Humax RM-H01U Remote Disassembly, Opening using a spudger: stap 2, afbeelding 3 van 3
      • Use a spudger, prying tool or a flatbed screwdriver to pry open the two halves. Start at the center.
      • The two halves are clamped together firmly.
      • Work your way to the front, and then back again on the other side.
      • See the next step for the location of the clips.
      Vraag FixBot
      Voeg opmerking toe
    3. Humax RM-H01U Remote Disassembly, Clip locations: stap 3, afbeelding 1 van 1
      • The clips are located 3 centimeters apart. The first clip is 1 centimeter from the front of the remote.
      • The hooks of the clips are on the bottom halve of the remote and face inward.
      • The top halve of the remote has indents where the clips grab into.
      Vraag FixBot
      Voeg opmerking toe
    4. Humax RM-H01U Remote Disassembly, All parts of the remote: stap 4, afbeelding 1 van 1
      • These are all the parts.
      • I cleaned all parts with a toothbrush first.
      • Then I cleaned the PCB and the back of the silicone buttons with pure alcohol.
      • Make sure not to brush too hard! You might remove the carbon layer that is applied. (It's the carbon layer that makes the electrical connection, so it's essential).
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jurrie
763 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 832
