Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
In this guide we are going to replace the LCD display on the Huawei ascend Y300 android smartphone. Before we start it is a good idea to prepare an organised area to carry out the repair, it is also a good Idea to get a small bowl or parts tray to put the small screws in so that they aren't lost.
Wat je nodig hebt
Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
Lift up and remove the battery
On the left of the motherboard there is a ribbon cable that connects the volume rocker to the motherboard, we need to disconnect it.
To do this, using either the spudger or tweezers lift up the retention flap holding the cable down.
Next using the tweezers carefully pull the ribbon cable away from the socket it was in until it is completely clear of the connector.
44 andere personen hebben deze handleiding voltooid.
2 opmerkingen
good
it a good advise and easy
Its really helpful and so easy ... thanks
