Ga door naar hoofdinhoud
Huawei P8 Lite Motherboard Replacement
Wat je nodig hebt
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Brayden Mann
639 Reputatie
4 handleidingen geschreven
Metro State, Team 1-2, Carpenter Spring 2016 Lid van Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Leden
7 handleidingen geschreven
4 opmerkingen
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - Antwoord
mine also need a new mother
anywr l can get it asap
blessed - Antwoord
Hey
I need p8 lite motherboard
goitsemodimo - Antwoord
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 8,136
