Inleiding
This guide will instruct step-by-step how to disassemble the Huawei P8 Lite and replace the earpiece speaker. A breakdown kit and a replacement earpiece speaker will be required. Review the device Teardown Guide to get started.
Wat je nodig hebt
Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
Use the tweezers to grip the earpiece speaker and lift the earpiece speaker from phone.
To reassemble your device, follow Teardown Guide steps 12, 6, 5, 4, 3, 2, 1 in that order.
