Inleiding
It can be very annoying If the USB port no longer works properly. The device then no longer charges reliably.
This guide will show you how to replace the USB port.
Wat je nodig hebt
Remove the SIM card by inserting a paper clip or a special tool into the hole on the SIM card tray until it comes out.
Remove the Torx T2 screws at the bottom of the case (next to the USB port)
Insert the opening tool on the lower end and in between the housing
Run the opening tool along the sides to open it
Lay the device face down and lift the back cover to the left
Red: Phillips #00 screws
Blue: Use the spudger to remove the covers
Use a spudger to remove the cable going to the back panel and those going over the battery
Yellow: Detach the antenna cable from the USB board
lift the speaker out by lifting it from the right or left. Warning: this may require some force as the speaker is glued.
Lift the USB board out .
If there are no silicone dust covers on the replacement part (like here on the aux port), then replace those from donor parts and place them on the new replacement part in the same orientation. This cover also serves to ensure that no light shines through the openings
Follow this guide in reversed order to reassemble your device.
Met dank aan deze vertalers:
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
