Ga door naar hoofdinhoud
Huawei Honor 10 Rear Glass Removal
Wat je nodig hebt
  1. Huawei Honor 10 Rear Glass Removal, Rear Glass: stap 1, afbeelding 1 van 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Rear Glass Removal: stap 2, afbeelding 1 van 3 Huawei Honor 10 Rear Glass Removal: stap 2, afbeelding 2 van 3 Huawei Honor 10 Rear Glass Removal: stap 2, afbeelding 3 van 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Rear Glass Removal: stap 3, afbeelding 1 van 2 Huawei Honor 10 Rear Glass Removal: stap 3, afbeelding 2 van 2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Rear Glass Removal: stap 4, afbeelding 1 van 3 Huawei Honor 10 Rear Glass Removal: stap 4, afbeelding 2 van 3 Huawei Honor 10 Rear Glass Removal: stap 4, afbeelding 3 van 3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Rear Glass Removal: stap 5, afbeelding 1 van 2 Huawei Honor 10 Rear Glass Removal: stap 5, afbeelding 2 van 2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Rear Glass Removal: stap 6, afbeelding 1 van 2 Huawei Honor 10 Rear Glass Removal: stap 6, afbeelding 2 van 2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
Conclusie
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Één andere persoon heeft deze handleiding voltooid.
Dominik Schnabelrauch
230.010 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.526 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 69
Altijd: 3,281
