Ga door naar hoofdinhoud
Hp Zbook studio g3 RAM Replacement
Wat je nodig hebt
    1. Hp Zbook studio g3  RAM Replacement, Removing the dust filter: stap 1, afbeelding 1 van 1
      • Remove the 4 screws holding down the dust filter
      • Remove the dust filter
      Vraag FixBot
      Voeg opmerking toe
    2. Hp Zbook studio g3  RAM Replacement, Removing the housing: stap 2, afbeelding 1 van 1
      • Remove the 4 outer screws.
      • Remove the 2 inner screws holding the housing down.
      • Now lift the housing. This may require some force
      Vraag FixBot
      Voeg opmerking toe
    3. Hp Zbook studio g3  RAM Replacement, Removing the old Ram module: stap 3, afbeelding 1 van 2 Hp Zbook studio g3  RAM Replacement, Removing the old Ram module: stap 3, afbeelding 2 van 2
      • Remove the old ram module by pushing these two tabs outwards. The module should swing up
      • Now pull the module out away from the holder
      • Note: The removal of the module should not require a lot of force
      Vraag FixBot
      Voeg opmerking toe
    4. Hp Zbook studio g3  RAM Replacement, Installing the new memory: stap 4, afbeelding 1 van 1
      • Orient the memory modules such that then notch in the connector lines up with the grove in the module
      • slide the module all the way into the holder such that the pins are in the connector
      • Push down on the module to lock it in the holders
      • Note: Make sure the module is in straight
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
jort
166 Reputatie
1 Handleiding geschreven
3Gids Commentaar
Would be really good to have one for the SSD
Andrew Hansford - Antwoord Deel
I am thinking of expanding the storage on this model. If I get around to it I’ll post a guide
jort - Antwoord Deel
For retail stores like me this is very helpful. I can send to customers so they can upgrade themselves. Thanks for sharing
My Website: Laptop Workstation cũ Tphcm
Laptop Titan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 54
Altijd: 4,988
