Inleiding
Do you have a shirt with straps that are too long? These instructions will teach you how to reduce the length of your shirt straps using a sewing machine. If at any time you feel confused by the terminology, please refer to iFixit's Sewing Glossary.
Wat je nodig hebt
Put on the shirt.
Pull the strap up until you reach your new desired length. Be sure to take the same amount of fabric from the front and the back of the seam.
Pin both straps to the desired length.
Thread the sewing machine and set it to your desired stitch length.
Align the pinned part of the shirt with the needle.
Put down the presser foot.
Sew along the line mapped out by your pins.
Pull out the pins as you sew. Make sure not to sew over any of them.
Make sure to backstitch at each end of the seam.
Repeat this step for each strap.
Cut excess fabric from the new seams, leaving ¼ inch to ½ inch.
Iron the seam allowance left after your cut to the back of the shirt.
Your shirt straps now should be secured at their new length.
