Ga door naar hoofdinhoud
How to remove and clean the buttons
Wat je nodig hebt
  1. How to remove and clean the buttons, How to remove and clean the buttons: stap 1, afbeelding 1 van 1
    • First, we need to get inside the camera. Refer to the lens cleaning guide for steps on how to remove the front panel.
  2. How to remove and clean the buttons: stap 2, afbeelding 1 van 1
    • Once you have the front panel off, you are one step closer to accessing the keys. From here, you will need to remove the upper panel which will release the keys. Unscrew the screw and remove the small metal plate which holds the keys.
  3. How to remove and clean the buttons: stap 3, afbeelding 1 van 2 How to remove and clean the buttons: stap 3, afbeelding 2 van 2
    • Remove the keys and clean using solution and a soft cloth. If the keys are damaged, you will need to replace them. You can purchase parts for your camera on Olympus's website.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 801
