Inleiding
After you’ve replaced or upgraded the SSD or hard drive in your Mac, and you’ve successfully installed macOS to the new drive, you’ll need to transfer any data you want from the old drive to the new one. This guide will show you how to use Migration Assistant to restore data from an old macOS drive or a Time Machine Backup to your new drive.
Wat je nodig hebt
Before you begin, connect your old macOS drive or a Time Machine backup drive to your computer.
Power on your Mac and open the Migration Assistant application.
More recent macOS screens won’t necessarily look like the example above. You may need to Find the migration assistant app. Run the Migration Assistant that’s on the drive to which you want the migrated data to go (in other words, the new drive). Ordinarily, you will have started up from the new drive. If you haven’t, you’ll need to select it as the Startup Disk.
Select all the items you'd like to transfer to your new drive.
At this point it is important to note that you have to wait until all data has been read. Otherwise, over 50% of the transmission may fail and the program will stop. without any feedback. !!!!! very important !!!!! wait until all data has been read, even if you can go on. only click on next if the actual data size is behind the selected points.
Once you begin the transfer, a loading bar will appear and cycle through each of the data categories that you selected on the previous screen (applications, documents, etc.).
When the transfer is complete, the Migration Complete window will appear.
Once all of your data is migrated, you can format your old drive and use it as an external drive with an SSD enclosure, or sell it for someone else to use!
29 andere personen hebben deze handleiding voltooid.
3 opmerkingen
You said you would be covering migrating to a “new drive” but you only showed migrating to a new computer. I have a new macbook pro, which has an internal SSD that is too small to migrate to, so I was planning on using a bigger external SSD as my main & bootup disk, and I want to migrate to that disk. If I bootup the new computer from the external disk, will the migration automatically go to the external disk? Or can you see another approach that would work?
thx
You know Bob, that is a good point! I guess I meant “new drive in a new computer.” RE: your situation, I think your proposed method should work. MacOS should either let you choose which drive you want to restore to (in which case you can choose the big external one), or it will just copy to the default / boot disk. If neither of those things happen and you can’t migrate everything directly to the external drive, you can try to do a partial restore to your small internal SSD by only selecting the crucial info from the restore menu, and then manually copy everything else over to the external SSD as a storage disk. I hope this helps, sorry for the misleading title!
thank you so much
