Inleiding
It appears Dolce Gusto Genio and Piccolo machine, and the ones alike, leak water either from top or bottom.
If your device leaks water from the capsules holder, you would like to read this guide before taking the whole machine apart.
In this guide I will shortly show what could indicate why the Capsule Piercing Plate (Diffuser plate) is the culprit.
Wat je nodig hebt
There is no reason to take the machine apart if the leak is not from the inside.
If the water runs down the cup bay (starting from where the red arrows are) it indicate a plate failure.
You will most likely also see a puddle of water at the base of your machine.[br]This comes from the water running backwards from the plate and into the machine.
You should try to clean or replace the plate first, before opening the machine.
Remove the capsule holder.
Close the lid (as if you were to make a brew)
Insert the small screwdriver at the point shown by the red arrow, press the screwdriver inwards 2->3 mm and the plate should drop down. There is a small spring behind which is moved. The spring sits on the plate. Due to lots of calcium deposits the plate may need a little help to come down.
Insert the new or cleaned plate, latch backend first and click in place in the front.
Once done, connect the device and make your self a brew and see if it is well-deserved. No Leaks - You've earned it. Leaks = You need that cup to ponder where the issue then is :-)
I’m really struggling to remove the plate. I’m scared of breaking it. Should I force it downwards or pull it out? It’s moved down slightly.
I had trouble too and broke a small screwdriver trying. It turns out, where the hole is isn’t the part that comes out. The hole where you need to put the screwdriver in stays put, but the screwdriver should release the plate which sits below the fixed piece of plastic that has the hole.
I had to use my fingers once the plate had loosened to pull it out. Mind the piercing needle that is on the plate.
Wenn die Platte stark verkalkt ist und man nachhelfen muss, sollte man darauf achten dass die kleine Aluminium Lasche welche die Platte hält nicht verbogen wurde. Sonst hält die Platte beim einsetzen nicht mehr richtig und das Kapselfach kann sich beim öffnen verkeilen da die Platte nicht richtig hoch geht. Dann einfach mit einer Pinzette ein wenig zurecht drücken und die Platte rastet wieder richtig ein.
I have updated this chapter to better describe how to get the plate out. It can be a bit tricky.
I just bought a piccolo xs, and used Dolce gusto Cappuccino pods, and Starbucks pods.
When I used Corsini espresso pods, water started coming out from the top.
Is this a fault with the machine, or the brand?
Is this common?
I get that sometimes with my Nespresso machine, so I just avoid brands that don't work well.
Is it the same with Dolce Gusto?
Brilliant explanation... had a little trouble getting plate out. once out saw build up of scale gave it a clean. Also did nozzle. Now works a dream. Thanks very much, saved it from going to landfill !
l'ho pulita ma fuoriesce ancora l'acqua. cosa posso fare?
Prova a cambiare tipo di capsule. A me è successo con una partita difettosa che non consentiva apertura in basso in fondo per la fuoriuscita del caffe.
Once done, connect the device again and make your self a brew to see if it is well-deserved.
Search for other guides in this forum. Search for "Dolce Gusto leaking water".
12 andere personen hebben deze handleiding voltooid.
8 opmerkingen
Hi there.
I have followed this and my plated was very scaled so cleaned an d put back but it still leaks. Same place. Any ideas?
I have a fontana but they all seem to have the same plate. Thanks
thanks for this easy to follow guide, ive finally fixed that pesky leak!
i was Stupid enough to buy the Nescafe Dolce Gusto and it started leaking so I replaced the piercing plate and I bet it hadnt even made more than 30 - 40 coffee’s the new plate has done about the same and started leaking again,
My advice is dont buy one of these machines unless you only want it as an ornament they are Crap and I wouldnt rate them as being worth anymore than about £5 tops.
Thank you so much! Your guide fixed the leak!
The leak happened shortly after I descaled the machine. There was a tiny sand-like grain, stucked inside the needle, probably blocking most of the flow.
Thank you!
Followed your instructions and have 1 cup of coffee , Thanks . Will wait and see last chance then the Bin beckons
I did it all but still leaking and there was no spring. Any other suggestions?
Utilissimo grazie
Rosanna Perobelli - Antwoord
My machine leaks the milk and coffee,
Ann Sims - Antwoord
