Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If your Sonicare is not as powerful as it used to be it could be because of a misalignment of the magnetic motor, e.g. if it's dropped. Philips built it like this on purpose and you need open the toothbrush and realign the magnetic motor.
Caution: Please only proceed if your toothbrush is out of warranty. If you are still within warranty then bring it back and get it fixed by professionals at Philips for free.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. First you need to open the toothbrush. This can be achieved by applying pressure to the lower end of the toothbrush which will alow the removal of the bottom cap.
    • First you need to open the toothbrush. This can be achieved by applying pressure to the lower end of the toothbrush which will alow the removal of the bottom cap.
    • To protect the toothbrush from being mared by whatever tool is used, apply some cardboard or similar between the tool and the toothbrush
  2. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  3. Once you have the insides out, you have to look for this area.
    • Once you have the insides out, you have to look for this area.
    • The silver red part are the two magnets. There needs to be a gap between the magnets and the metalic driver
    • If your magnets are contacting, or are very close to them, please proceed with the next step.
  4. The magnets are secured by two screws. One is easily accessible on the back of the toothbrush.
    • The magnets are secured by two screws. One is easily accessible on the back of the toothbrush.
    • The screw is mounted in a slot to allow for some adjustments. For whatever reason the screw has moved to the top of the brush, this will let the Magnets touch the driver which reduces the motion and power of the brush significantly.
    • Loosen the screw on this side.
  5. Apply some pressure to remove the circuit board and get access to the screw holding the magnets on the front side.
    • Apply some pressure to remove the circuit board and get access to the screw holding the magnets on the front side.
    • If is has moved, loosen the screw, position the the magnets in a way that there is a gap between magnets and driver and fasten both screws.
Conclusie
Repeat the steps in reverse order to reassemble your device.
60 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
moritz
1.518 Reputatie
1 Handleiding geschreven
Hi there, this was my problem combined with the loose actuator screw. Mine works great now. I used a credit card as a spacer between the magnets and windings, do you know if more space is necessary for the best performance?
Clys - Antwoord
Saved me ~$100! Awesome!
chip - Antwoord
Good manual, I could fix the gap between the magnets. However, that was not the problem in my toothbrush. After pressing the power button the light for the selected program flashes once and after that all flash on and the toothbrush shuts down. It refises to start anything, it's almost as of there is a counter for the maximum amount of charges.
Jan Huijsmans - Antwoord
saved me from buying a new toothbrush, thanks!
Diederik Knaapen - Antwoord
Have the same question as Clys.Wish I could know the correct gap measurement.I also used a credit card,which measured .9mm.Maybe 1mm is the correct gap.I know that if I contact Philips the chances of reaching anyone knowing anything would likely be impossible.If I bought a new brush,took it apart,that would be a way of finding out.
jrj90620 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 39
Afgelopen 7 dagen: 420
Afgelopen 30 dagen: 1,905
Altijd: 72,031
