Ga door naar hoofdinhoud
How to fix a Kindle Voyage stuck in a boot loop
Wat je nodig hebt
  1. How to fix a Kindle Voyage stuck in a boot loop, Back Panel: stap 1, afbeelding 1 van 2 How to fix a Kindle Voyage stuck in a boot loop, Back Panel: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. How to fix a Kindle Voyage stuck in a boot loop: stap 2, afbeelding 1 van 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. How to fix a Kindle Voyage stuck in a boot loop: stap 3, afbeelding 1 van 3 How to fix a Kindle Voyage stuck in a boot loop: stap 3, afbeelding 2 van 3 How to fix a Kindle Voyage stuck in a boot loop: stap 3, afbeelding 3 van 3
    • Once the screws are removed, the back panel can slide off the device.
  4. How to fix a Kindle Voyage stuck in a boot loop: stap 4, afbeelding 1 van 2 How to fix a Kindle Voyage stuck in a boot loop: stap 4, afbeelding 2 van 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. How to fix a Kindle Voyage stuck in a boot loop, Remove the motherboard: stap 5, afbeelding 1 van 1
    • Make sure to remove all connectors, then remove all the screws.
    • You should be able to remove the motherboard from the case.
    • Remove the battery connector first.
  6. How to fix a Kindle Voyage stuck in a boot loop, Solder thin wires to RX, TX, and GND: stap 6, afbeelding 1 van 1
    • The three wires should go on the pads outlined in red.
    • From left to right, the pins are TX, RX, and GND.
    • If you are finding it difficult to solder to the ground pin, try soldering to one of the shields, which would normally be where the blue outline is.
    • Put the motherboard back into the Kindle, but don't re-connect the battery.
  7. How to fix a Kindle Voyage stuck in a boot loop, Build the circuit on the breadboard and connect the Kindle: stap 8, afbeelding 1 van 1
    • Using the resistors, diodes, USB serial adapter, and breadboard wires, build this circuit on the breadboard.
    • If you don't know how to use a breadboard, YouTube is a great place to learn.
    • Sorry for the stupid cropping of the image, iFixit doesn't like it. See the full image at https://www.mobileread.com/forums/showth...
    • Then, using alligator clips, connect the wires on the "kindle" side of the schematic to the appropriate wires from the Kindle.
    • Plug your USB serial adapter into the computer.
    • Start your serial terminal program (like Minicom). Make sure to disable "Hardware Flow Control".
  8. How to fix a Kindle Voyage stuck in a boot loop, Connect the Kindle battery and start diagnostic mode: stap 10, afbeelding 1 van 1
    • Connect the kindle battery.
    • You'll start seeing text in the serial terminal. When it says "Hit any key to stop autoboot" press a key.
    • Type in "bootm 0xE41000 " and press enter.
  9. How to fix a Kindle Voyage stuck in a boot loop, Upload firmware to Kindle: stap 11, afbeelding 1 van 1
    • Tap "U - USB Export" on the screen.
    • Plug your Kindle into your computer through the Kindle's USB port.
    • Download the Kindle firmware from https://www.amazon.com/gp/help/customer/...
    • Open the Kindle drive on your computer and drag the .bin file into it.
    • Eject your Kindle and unplug it from your computer.
    • Press "Q" either onscreen or in your serial terminal.
    • Tap "Reboot or Disable Diags", or type "D"
    • Tap "Reboot System", or type "R"
  10. How to fix a Kindle Voyage stuck in a boot loop, Flash new firmware: stap 12, afbeelding 1 van 1
    • The Kindle should now be booting into the regular OS.
    • When the serial terminal says "Press [ENTER] for recovery menu...", press enter.
    • Type "u" and quickly follow that with the enter key.
    • Your kindle will restore the firmware you copied over previously.
    • At the end of this process, your Kindle should be showing its bookshelf screen.
    • Unplug the USB to serial adapter, and remove the wires from the kindle.
    • If your wires are thin enough, you may be able to break them away from the pad, but be careful to not tear the pad off.
    • If you can't do that or just want to be safe, remove the motherboard and desolder the wires, then re-install the motherboard.
Conclusie
To complete the repair, close the device by following the process detailed in the beginning in reverse.
Één andere persoon heeft deze handleiding voltooid.
Merlin04
169 Reputatie
1 Handleiding geschreven
Één opmerking
Merlin04, you do an excellent job at breaking down the tasks and guiding a person through the process!!
Jennifer Gehman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 50
Altijd: 2,676
