Ga door naar hoofdinhoud
How to fix Mobee Magic Mouse disconnection issues
Wat je nodig hebt
Video-instructies
Eindstreep
31 andere personen hebben deze handleiding voltooid.
Peter Barnett
771 Reputatie
1 Handleiding geschreven
Dragon Upstream Consulting Limited Lid van Dragon Upstream Consulting Limited
Business
1 Lid
5 handleidingen geschreven
5Gids Commentaar
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Antwoord Deel
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Antwoord Deel
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Antwoord Deel
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Antwoord Deel
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 121
Altijd: 41,642
