Ga door naar hoofdinhoud
How to clean Microtek ScanMaker 5900 glass
Wat je nodig hebt
  1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: stap 1, afbeelding 1 van 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: stap 1, afbeelding 2 van 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: stap 1, afbeelding 3 van 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    Vraag FixBot
    Voeg opmerking toe
  2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: stap 2, afbeelding 1 van 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: stap 2, afbeelding 2 van 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: stap 2, afbeelding 3 van 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    Vraag FixBot
    Voeg opmerking toe
  3. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: stap 3, afbeelding 1 van 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: stap 3, afbeelding 2 van 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: stap 3, afbeelding 3 van 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    Vraag FixBot
    Voeg opmerking toe
  4. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: stap 4, afbeelding 1 van 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: stap 4, afbeelding 2 van 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: stap 4, afbeelding 3 van 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
    Vraag FixBot
    Voeg opmerking toe
  5. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: stap 5, afbeelding 1 van 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: stap 5, afbeelding 2 van 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: stap 5, afbeelding 3 van 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
    Vraag FixBot
    Voeg opmerking toe
  6. How to clean Microtek ScanMaker 5900 glass, How to clean Microtek ScanMaker 5900 glass: stap 6, afbeelding 1 van 1
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Steven Shaginyan
39 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-9, Regan Fall 2011 Lid van Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 36
Altijd: 3,003
