Ga door naar hoofdinhoud
How to adjust the 2006 Iron Horse Warrior front derailleur
Wat je nodig hebt
  1. How to adjust the 2006 Iron Horse Warrior front derailleur, How to adjust the 2006 Iron Horse Warrior front derailleur: stap 1, afbeelding 1 van 1
    • Shift the front derailleur to the 1st position (smallest cog and closest to the body of the bike)
    • Adjust the "Low" screw with a screwdriver so the derailleur lines up vertically with the 1st gear.
    • Test your gears by holding your back tire off the ground and pedaling while you shift through your gears. If it is aligned correctly, the chain will not rub on the derailleur.
  2. How to adjust the 2006 Iron Horse Warrior front derailleur: stap 2, afbeelding 1 van 1
    • Shift to 3rd gear (the largest cog and farthest from the body of the bike)
    • Adjust the derailleur until it lines up vertically with the 3rd gear
    • The same rules apply for this one as when setting the lower bound. However, you want the smallest gap possible between the outer edge of the chain and the guard. The smaller gap will allow your bike to downshift much easier.
    • The derailleur should be aligned now, but if you are unable to move the derailleur far enough away from the frame, you may need to tighten the cable itself. If so, proceed to Step 3.
  3. How to adjust the 2006 Iron Horse Warrior front derailleur: stap 3, afbeelding 1 van 1
    • This step is only required if you were unable to align the derailleur in Step 2
    • To tighten the cable, place the derailleur in the 1st gear position. This position requires the least amount of tension on the cable.
    • Loosen the 6mm hex nut using an Allen wrench just enough to allow the cable to come free.
    • Pull the cable using your hands as tight as you can. Replace the cable under the screw and tighten the screw by turning it clockwise.
    • Repeat Step 2 to set the upper bound on the derailleur. Now that the cable is tight, the derailleur will be able to travel further away from the frame of the bike and line up with the 3rd gear.
Conclusie
Matt Halvorson
354 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-2, Amido Spring 2015 Lid van Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 1,573
