Ga door naar hoofdinhoud
How to adjust Razor A steering column
    1. How to adjust Razor A steering column, How to adjust Razor A steering column: stap 1, afbeelding 1 van 2 How to adjust Razor A steering column, How to adjust Razor A steering column: stap 1, afbeelding 2 van 2
      • Locate the tightening assembly. The tightening assembly consists of:
      • An upper nut
      • A lower nut
      Vraag FixBot
      Voeg opmerking toe
    2. How to adjust Razor A steering column: stap 2, afbeelding 1 van 1
      • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
      • If loosening the steering column, follow these steps:
      • Turn the upper nut counterclockwise.
      • Turn the lower nut counterclockwise until it is tight against the upper nut.
      • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
      • If tightening the steering column, follow these steps:
      • Turn the lower nut clockwise until reaching the desired steering column tightness.
      • Turn the upper nut clockwise until it is tight against the lower nut.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Jordyn
565 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-13, Amido Fall 2012 Lid van Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Leden
10 handleidingen geschreven
8Gids Commentaar
what move it with your hands? - didn't help
Heather McCasland - Antwoord Deel
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 - Antwoord Deel
Thanks you! Why doesn't the owners manual have this?
Jessica - Antwoord Deel
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Antwoord Deel
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 120
Altijd: 44,163
