Ga door naar hoofdinhoud
How to Use Suction Tape
  1. How to Use Suction Tape, Choose the tape: stap 1, afbeelding 1 van 2 How to Use Suction Tape, Choose the tape: stap 1, afbeelding 2 van 2
    • If you want to secure one side of your two-panel device, skip to this step.
    • If you want to buffer a difficult surface on your device, move to the next step.
    Vraag FixBot
    Voeg opmerking toe
  2. How to Use Suction Tape, Measure the tape: stap 2, afbeelding 1 van 3 How to Use Suction Tape, Measure the tape: stap 2, afbeelding 2 van 3 How to Use Suction Tape, Measure the tape: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • Measure the length of tape you want and mark it with a pen. Consider the following:
    • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
    • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
    Vraag FixBot
    Voeg opmerking toe
  3. How to Use Suction Tape, Cut the tape: stap 3, afbeelding 1 van 3 How to Use Suction Tape, Cut the tape: stap 3, afbeelding 2 van 3 How to Use Suction Tape, Cut the tape: stap 3, afbeelding 3 van 3
    • Use scissors to cut the tape to the desired length.
    • Repeat the measuring and cutting procedure for each piece of tape required.
    Vraag FixBot
    Voeg opmerking toe
  4. How to Use Suction Tape, Peel the tape: stap 4, afbeelding 1 van 2 How to Use Suction Tape, Peel the tape: stap 4, afbeelding 2 van 2
    • Peel the tape off its plastic liner.
    Vraag FixBot
    Voeg opmerking toe
  5. How to Use Suction Tape, Apply the tape: stap 5, afbeelding 1 van 3 How to Use Suction Tape, Apply the tape: stap 5, afbeelding 2 van 3 How to Use Suction Tape, Apply the tape: stap 5, afbeelding 3 van 3
    • Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
    Vraag FixBot
    Voeg opmerking toe
  6. How to Use Suction Tape, Secure the tape: stap 6, afbeelding 1 van 3 How to Use Suction Tape, Secure the tape: stap 6, afbeelding 2 van 3 How to Use Suction Tape, Secure the tape: stap 6, afbeelding 3 van 3
    • Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
    • Use a spudger to press out any large bubbles.
    Vraag FixBot
    Voeg opmerking toe
  7. How to Use Suction Tape, Open the device: stap 7, afbeelding 1 van 2 How to Use Suction Tape, Open the device: stap 7, afbeelding 2 van 2
    • Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
    • You're now ready to open your device!
    • Follow this guide for general instructions on how to use the Anti-Clamp.
    Vraag FixBot
    Voeg opmerking toe
  8. How to Use Suction Tape, Measure the tape: stap 8, afbeelding 1 van 3 How to Use Suction Tape, Measure the tape: stap 8, afbeelding 2 van 3 How to Use Suction Tape, Measure the tape: stap 8, afbeelding 3 van 3
    • The remaining steps show how to secure one side of your two-panel device.
    • Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
    • In this example, we want to open the screen, so we'll secure the blue back cover.
    • You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
    • Use enough tape to ensure a good hold on the panel you don't want to open.
    • Don't cover the power button with tape, or you might accidentally turn on the device.
    Vraag FixBot
    Voeg opmerking toe
  9. How to Use Suction Tape, Peel the tape: stap 9, afbeelding 1 van 2 How to Use Suction Tape, Peel the tape: stap 9, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  10. How to Use Suction Tape, Cut the tape: stap 10, afbeelding 1 van 2 How to Use Suction Tape, Cut the tape: stap 10, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  11. How to Use Suction Tape, Apply the tape: stap 11, afbeelding 1 van 3 How to Use Suction Tape, Apply the tape: stap 11, afbeelding 2 van 3 How to Use Suction Tape, Apply the tape: stap 11, afbeelding 3 van 3
    • Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
    • Don't fold the tape over the panel you want to open, as this might hinder the opening procedure.
    Vraag FixBot
    Voeg opmerking toe
  12. How to Use Suction Tape, Fold the tape: stap 12, afbeelding 1 van 3 How to Use Suction Tape, Fold the tape: stap 12, afbeelding 2 van 3 How to Use Suction Tape, Fold the tape: stap 12, afbeelding 3 van 3
    • Fold the tape onto the panel you don't want to open.
    • Use your fingers to press down the tape and firmly secure it to your device.
    Vraag FixBot
    Voeg opmerking toe
  13. How to Use Suction Tape, Open the device: stap 13, afbeelding 1 van 2 How to Use Suction Tape, Open the device: stap 13, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
Conclusie
For other general electronics skills guides, click here.
7 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
244.814 Reputatie
1.203 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
28.236 handleidingen geschreven
3Gids Commentaar
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
Arturo - Antwoord Deel
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
Kevin Smith - Antwoord Deel
I would like to check the material of this product. Anyone can help me?
Nguyễn Thị Vân Anh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 292
Altijd: 11,911
