Ga door naar hoofdinhoud
How to True a Bent Bicycle Rim Using Common Tools
Wat je nodig hebt
    1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: stap 1, afbeelding 1 van 1
      • Bring your bike somewhere with ample space so you have room to work.
      Vraag FixBot
      Voeg opmerking toe
    2. How to True a Bent Bicycle Rim Using Common Tools: stap 2, afbeelding 1 van 3 How to True a Bent Bicycle Rim Using Common Tools: stap 2, afbeelding 2 van 3 How to True a Bent Bicycle Rim Using Common Tools: stap 2, afbeelding 3 van 3
      • Flip the bike on its seat so the wheel can spin freely.
      • Use the spokes to spin the affected wheel.
      • Continue spinning the wheel until it is clear where the bend is occurring.
      Vraag FixBot
      Voeg opmerking toe
    3. How to True a Bent Bicycle Rim Using Common Tools: stap 3, afbeelding 1 van 2 How to True a Bent Bicycle Rim Using Common Tools: stap 3, afbeelding 2 van 2
      • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
      Vraag FixBot
      Voeg opmerking toe
    4. How to True a Bent Bicycle Rim Using Common Tools: stap 4, afbeelding 1 van 3 How to True a Bent Bicycle Rim Using Common Tools: stap 4, afbeelding 2 van 3 How to True a Bent Bicycle Rim Using Common Tools: stap 4, afbeelding 3 van 3
      • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
      Vraag FixBot
      Voeg opmerking toe
    5. How to True a Bent Bicycle Rim Using Common Tools: stap 5, afbeelding 1 van 2 How to True a Bent Bicycle Rim Using Common Tools: stap 5, afbeelding 2 van 2
      • Pluck the spoke and listen to the pitch to check its tightness.
      • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
      Vraag FixBot
      Voeg opmerking toe
    6. How to True a Bent Bicycle Rim Using Common Tools: stap 6, afbeelding 1 van 2 How to True a Bent Bicycle Rim Using Common Tools: stap 6, afbeelding 2 van 2
      • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
      Vraag FixBot
      Voeg opmerking toe
    7. How to True a Bent Bicycle Rim Using Common Tools: stap 7, afbeelding 1 van 1
      • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
      • Repeat the tightening/loosening process accordingly if necessary.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Charles Tweedy
199 Reputatie
1 Handleiding geschreven
UCD-MORRIS-S23S1G4 Lid van UCD-MORRIS-S23S1G4
Community
2 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 61
Altijd: 2,253
