Ga door naar hoofdinhoud
How to Replace Keys on a Keyboard
Wat je nodig hebt
    1. How to Replace Keys on a Keyboard, Individual Keys: stap 1, afbeelding 1 van 2 How to Replace Keys on a Keyboard, Individual Keys: stap 1, afbeelding 2 van 2
      • Loosen the key by prying all four corners gently with your spudger.
      • Make sure your keyboard is unplugged before performing any of these steps.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Replace Keys on a Keyboard: stap 2, afbeelding 1 van 2 How to Replace Keys on a Keyboard: stap 2, afbeelding 2 van 2
      • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
      • If the key will not come out, or seems like too much force is needed, try step one again.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Replace Keys on a Keyboard: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
      • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Replace Keys on a Keyboard: stap 4, afbeelding 1 van 1
      • Clean your keys with compressed air by blowing around the removed key.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Replace Keys on a Keyboard: stap 5, afbeelding 1 van 2 How to Replace Keys on a Keyboard: stap 5, afbeelding 2 van 2
      • Push in the clean keys until you hear a popping sound.
      • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
      • If you removed multiple keys, make sure they are in their proper spot and orientation.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Congratulations! You now have a keyboard with fully functional keys!
7 andere personen hebben deze handleiding voltooid.
Cooper
502 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-6, Green Winter 2015 Lid van Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Leden
28 handleidingen geschreven
2Gids Commentaar
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Antwoord Deel
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 195
Altijd: 21,618
