Ga door naar hoofdinhoud
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
Wat je nodig hebt
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 1, afbeelding 1 van 1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 2, afbeelding 1 van 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 2, afbeelding 2 van 2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 3, afbeelding 1 van 1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 4, afbeelding 1 van 1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 5, afbeelding 1 van 1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 6, afbeelding 1 van 1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 7, afbeelding 1 van 1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 8, afbeelding 1 van 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 8, afbeelding 2 van 2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 9, afbeelding 1 van 1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 10, afbeelding 1 van 1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 11, afbeelding 1 van 1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 12, afbeelding 1 van 1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: stap 13, afbeelding 1 van 1
    • You are now finished!
Eindstreep
John Hiller
110 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,852
