Ga door naar hoofdinhoud
How to Repair Your Torn Sleeping Bag
Wat je nodig hebt
  1. How to Repair Your Torn  Sleeping Bag, How to Repair Your Torn  Sleeping Bag: stap 1, afbeelding 1 van 1
    • Push any stuffing/down filling back into the hole.
    • You can use your finger, but depending on the size of the hole you may want to use a smaller object so that it doesn't tear further.
  2. How to Repair Your Torn  Sleeping Bag: stap 2, afbeelding 1 van 3 How to Repair Your Torn  Sleeping Bag: stap 2, afbeelding 2 van 3 How to Repair Your Torn  Sleeping Bag: stap 2, afbeelding 3 van 3
    • Take your roll of duct tape and cut off a small amount (about as long as the tear)
  3. How to Repair Your Torn  Sleeping Bag: stap 3, afbeelding 1 van 1
    • Fold the edges of the tear back towards the stuffing so that you create a clean edge with no fraying.
    • This makes it easier to apply the duct tape.
  4. How to Repair Your Torn  Sleeping Bag: stap 4, afbeelding 1 van 1
    • Apply the duct tape to each half of the tear and fold it under, creating a cuff/edge of duct tape
    • This will allow you to sew the fabric without tearing it.
  5. How to Repair Your Torn  Sleeping Bag: stap 5, afbeelding 1 van 1
    • Take a small needle and thread it with thread of similar color to the sleeping bag material (can be any color but a similar one makes the fix less noticeable)
    • Working with needles can be dangerous.
  6. How to Repair Your Torn  Sleeping Bag: stap 6, afbeelding 1 van 3 How to Repair Your Torn  Sleeping Bag: stap 6, afbeelding 2 van 3 How to Repair Your Torn  Sleeping Bag: stap 6, afbeelding 3 van 3
    • Push the two pieces of duct tape together and use the needle and thread to sew them together with a whip stitch.
  7. How to Repair Your Torn  Sleeping Bag: stap 7, afbeelding 1 van 3 How to Repair Your Torn  Sleeping Bag: stap 7, afbeelding 2 van 3 How to Repair Your Torn  Sleeping Bag: stap 7, afbeelding 3 van 3
    • Pull the thread tight when you reach the end of the tape and tie a knot in the string
    • Cut off any remaining thread.
  8. How to Repair Your Torn  Sleeping Bag: stap 8, afbeelding 1 van 2 How to Repair Your Torn  Sleeping Bag: stap 8, afbeelding 2 van 2
    • Cut off any remaining duct tape.
    • Be wary of a sticky residue that may be left behind from the duct tape if pulled off to remove excess
    • Enjoy your newly patched sleeping bag!
Eindstreep
Michelle Stovall
128 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-4, Green Fall 2015 Lid van Cal Poly, Team 10-4, Green Fall 2015
CPSU-GREEN-F15S10G4
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 6,144
