Inleiding
This guide will be helpful for repairing your faulty wires if the troubleshooting page recommends that you replace them. This is a necessary step when you have determined no other way to repair your current wires. Be wary of accidentally damaging other parts of the device when replacing wires.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Begin by removing the two main black face plates on either end of the speaker tube using a Phillips head PH1 screwdriver fitting to remove a total of four screws.
2 on top on of either end of the speaker, 2 on bottom of either end of the speaker.
Assuming you have enough wire length to spare, insert the bare wire into a wire butt connector so it just passes the nub on one end.
Then use a wire crimping tool to crimp the the butt connector, therefore making a solid contact connection.
Repeat for the loose wire into the other end of the same wire butt connector.
