Ga door naar hoofdinhoud
How to Repair Sony WI-C200 In-Ear Headphones
Wat je nodig hebt
  1. How to Repair Sony WI-C200 In-Ear Headphones, How to Repair Sony WI-C200 In-Ear Headphones: stap 1, afbeelding 1 van 3 How to Repair Sony WI-C200 In-Ear Headphones, How to Repair Sony WI-C200 In-Ear Headphones: stap 1, afbeelding 2 van 3 How to Repair Sony WI-C200 In-Ear Headphones, How to Repair Sony WI-C200 In-Ear Headphones: stap 1, afbeelding 3 van 3
    • Wedge the edge of a spudger between the two cases holding the circuit board, then pry open the cases.
    • Wedge the edge of a spudger between the two cases, then pry the cases apart.
  2. How to Repair Sony WI-C200 In-Ear Headphones: stap 2, afbeelding 1 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 2, afbeelding 2 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 2, afbeelding 3 van 3
    • Remove the top casing with the volume controls.
    • Remove the side tabs connecting the wires to the circuit board carefully.
  3. How to Repair Sony WI-C200 In-Ear Headphones: stap 3, afbeelding 1 van 2 How to Repair Sony WI-C200 In-Ear Headphones: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use ESD-safe tweezers to remove the board from the bottom case .
  4. How to Repair Sony WI-C200 In-Ear Headphones: stap 4, afbeelding 1 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 4, afbeelding 2 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 4, afbeelding 3 van 3
    • After prying open the earbud, push the wire outwards from the casing, extending the speaker.
    • Slowly slide the casing away from the connections.
  5. How to Repair Sony WI-C200 In-Ear Headphones: stap 5, afbeelding 1 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 5, afbeelding 2 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 5, afbeelding 3 van 3
    • Place the positive probe of the multimeter on the pin of the red circuit board connection.
    • Place the negative probe on the pin of the red connection on the earbud.
    • Measure the voltage across the pins. If the connections yield 0 V, desolder the pins.
    • Apply the last three steps for the orange connection to measure the voltage across the pins. Desolder the pins if the connection yield 0 V.
    • Soldering/desoldering presents potential for device damage and burns. Always solder/desolder in a well-ventilated area.
  6. How to Repair Sony WI-C200 In-Ear Headphones: stap 6, afbeelding 1 van 2 How to Repair Sony WI-C200 In-Ear Headphones: stap 6, afbeelding 2 van 2
    • Use lead-free solder to solder the connections.
  7. How to Repair Sony WI-C200 In-Ear Headphones: stap 7, afbeelding 1 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 7, afbeelding 2 van 3 How to Repair Sony WI-C200 In-Ear Headphones: stap 7, afbeelding 3 van 3
    • Place the circuit board back into the bottom casing.
    • Press the side tabs of the connections back into the bottom casing.
  8. How to Repair Sony WI-C200 In-Ear Headphones: stap 8, afbeelding 1 van 2 How to Repair Sony WI-C200 In-Ear Headphones: stap 8, afbeelding 2 van 2
    • Apply adhesive around the rims of the bottom casing holding the circuit board.
    • Firmly press the top and bottom case together, then wait a couple minutes for the adhesive to cure.
  9. How to Repair Sony WI-C200 In-Ear Headphones: stap 9, afbeelding 1 van 2 How to Repair Sony WI-C200 In-Ear Headphones: stap 9, afbeelding 2 van 2
    • Apply adhesive around the rims of one of the earbud casings.
    • Press the two sides of the earbud casings together, and wait for a couple of minutes for the adhesive to cure.
Conclusie
Enjoy your refreshed earbuds!
Anjali Abraham
169 Reputatie
1 Handleiding geschreven
Één opmerking
Si el problema es el micrófono, cómo lo reemplazo?
mexicorrosivo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 189
Altijd: 9,274
