Inleiding
Use this guide to remove the top panel in your LG WM3050CW Washing Machine.
Removing the top panel gives you access to many of the washer's internal components, such as the detergent dispenser, main control board, air dome, etc.
Wat je nodig hebt
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
Repair didn’t go as planned? Ask our Answers community for help.
