Inleiding
Use this guide to remove the rear panel in your LG front load washing machine.
Removing the rear panel gives you access to many internal components, such as the direct drive motor, dampers, and more.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Wat je nodig hebt
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Repair didn’t go as planned? Ask our Answers community for help.
