Ga door naar hoofdinhoud
How to Reattach a Backpack Grab Handle
Wat je nodig hebt
    1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: stap 1, afbeelding 1 van 3 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: stap 1, afbeelding 2 van 3 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: stap 1, afbeelding 3 van 3
      • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
      • Caution: Be careful when using scissors this way.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Reattach a Backpack Grab Handle: stap 2, afbeelding 1 van 2 How to Reattach a Backpack Grab Handle: stap 2, afbeelding 2 van 2
      • Open up the inner seam at the same spot using a pair of scissors.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Reattach a Backpack Grab Handle: stap 3, afbeelding 1 van 2 How to Reattach a Backpack Grab Handle: stap 3, afbeelding 2 van 2
      • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Reattach a Backpack Grab Handle: stap 4, afbeelding 1 van 3 How to Reattach a Backpack Grab Handle: stap 4, afbeelding 2 van 3 How to Reattach a Backpack Grab Handle: stap 4, afbeelding 3 van 3
      • Thread your sewing needle.
      • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Reattach a Backpack Grab Handle: stap 5, afbeelding 1 van 3 How to Reattach a Backpack Grab Handle: stap 5, afbeelding 2 van 3 How to Reattach a Backpack Grab Handle: stap 5, afbeelding 3 van 3
      • Hold the edge of your grab handle down at the the first seam you opened.
      • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
      • Caution: Sewing needles are sharp; be careful not to poke yourself.
      • This repair only requires one of these two basic stitching methods.
      Vraag FixBot
      Voeg opmerking toe
    6. How to Reattach a Backpack Grab Handle: stap 6, afbeelding 1 van 2 How to Reattach a Backpack Grab Handle: stap 6, afbeelding 2 van 2
      • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
      • Use one of these basic stitching methods.
      Vraag FixBot
      Voeg opmerking toe
    7. How to Reattach a Backpack Grab Handle: stap 7, afbeelding 1 van 3 How to Reattach a Backpack Grab Handle: stap 7, afbeelding 2 van 3 How to Reattach a Backpack Grab Handle: stap 7, afbeelding 3 van 3
      • Cut off the remaining thread and tie it into a knot.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Once you have completed this guide, you will be able to make use of your grab handle once again.
5 andere personen hebben deze handleiding voltooid.
Onyinyechi Onyeagucha
342 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 187
Altijd: 11,695
