Ga door naar hoofdinhoud
How to JBL L40
Wat je nodig hebt
  1. How to JBL L40, How to JBL L40: stap 1, afbeelding 1 van 1
    • To remove the speaker from the cabinet, unscrew the 4 screws being careful not to slip and pierce the paper cone.
    • Once the screws are removed gently pull the speaker out of the cabinet.
    • There will be 2 wires attached to the speaker, remove them making sure to mark the polarity of them if they are not marked already.
    Vraag FixBot
    Voeg opmerking toe
  2. How to JBL L40: stap 2, afbeelding 1 van 1
    • Here is the speaker removed from the cabinet, you can clearly see the degraded state of the foam surround. Luckily this makes it very easy to remove it.
    • These next steps require careful attention to detail. Work slowly and carefully. You do not want to puncture/tear/rip the paper cone or any other components.
    Vraag FixBot
    Voeg opmerking toe
    • Remove the black foam ring.
    • Try to do as much of this by hand as you can. You do not want to damage the ring as you will need it for re assembly.
    • Carefully run your knife between the ring and the outer metal edge.
    • Now using your hands and knife when needed remove the black ring from the speaker frame. Prying slowly. Take care not to tear it.
    • Once the ring is removed rub all of the old foam surround off and set aside for reassembly
    Vraag FixBot
    Voeg opmerking toe
    • Remove all of the old foam surround from the cone and speaker frame. It was so crumbly on mine that all it took was a bunch of rubbing with my fingers. If you are having trouble use your knife, but again be careful.
    Vraag FixBot
    Voeg opmerking toe
  3. How to JBL L40: stap 5, afbeelding 1 van 1
    • You can see some of the glue seeped out, it will dry clear so don't worry.
    Vraag FixBot
    Voeg opmerking toe
  4. How to JBL L40: stap 6, afbeelding 1 van 1
    • Spread glue on the ring you removed earlier
    • place over the foam ring and press on securly
    • allow everything over night to dry completely.
    Vraag FixBot
    Voeg opmerking toe
  5. How to JBL L40: stap 7, afbeelding 1 van 1
    • Connect the wires to the speaker being mindfull of the polarity.
    • Gently fit the speaker into the housing
    • Line up the screws and progressively tighten them until the speaker is secured
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
David Salerno
823 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 69
Altijd: 7,820
