Ga door naar hoofdinhoud
How to Fix a Correcting Tape
Wat je nodig hebt
  1. How to Fix a Correcting Tape, How to Fix a Correcting Tape: stap 1, afbeelding 1 van 2 How to Fix a Correcting Tape, How to Fix a Correcting Tape: stap 1, afbeelding 2 van 2
    • From the button, open the case of the correcting tape.
  2. How to Fix a Correcting Tape: stap 2, afbeelding 1 van 2 How to Fix a Correcting Tape: stap 2, afbeelding 2 van 2
    • Cut from the middle of the extra correcting tape and remove those used parts.
    • Cut off those used parts from the place near the small gear.
  3. How to Fix a Correcting Tape: stap 3, afbeelding 1 van 1
    • Cut a small piece of the scotch tape.
  4. How to Fix a Correcting Tape: stap 4, afbeelding 1 van 1
    • Connect the remaining correction tape to the small gear by using a small piece of scotch tape.
  5. How to Fix a Correcting Tape: stap 5, afbeelding 1 van 1
    • After the connection is made, wrap the used tape tightly around the gear.
    • Put all the parts back in place.
  6. How to Fix a Correcting Tape: stap 6, afbeelding 1 van 1
    • Close the case of the correcting tape and snap back to place.
  7. How to Fix a Correcting Tape: stap 7, afbeelding 1 van 1
    • You're done!
Conclusie
5 andere personen hebben deze handleiding voltooid.
Yi Luo
220 Reputatie
1 Handleiding geschreven
UC Davis, Team S2-G5, Bender Fall 2018 Lid van UC Davis, Team S2-G5, Bender Fall 2018
UCD-BENDER-F18S2G5
2 Leden
1 handleiding geschreven
3 opmerkingen
It probably cost me more time to put it together (first time) than it would to buy a new one. Doesn’t matter, fixed a problem! A sense of accomplishment and pride. %#*@, I love it so much.
Thanks for the guide.
The Swanson Disciple - Antwoord
This stuff is absolute junk! Wish I could find it packaged the old way, like Avery correction tape used to be, in little cardboard boxes. Hate all that plastic and these things always break for me!
Laker Girl - Antwoord
Well thank you for helping us and that was quite a shot thank you and god bless you and be safe during the virus!
Peata Faalaa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 122
Altijd: 34,658
