Ga door naar hoofdinhoud
How to Fix Broken Powder Make-up
Wat je nodig hebt
    1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: stap 1, afbeelding 1 van 3 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: stap 1, afbeelding 2 van 3 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: stap 1, afbeelding 3 van 3
      • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Fix Broken Powder Make-up: stap 2, afbeelding 1 van 3 How to Fix Broken Powder Make-up: stap 2, afbeelding 2 van 3 How to Fix Broken Powder Make-up: stap 2, afbeelding 3 van 3
      • Pour a small amount of rubbing alcohol into the cap.
      • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
      • Do not use more than two caps worth of rubbing alcohol.
      Vraag FixBot
      Voeg opmerking toe
    3. How to Fix Broken Powder Make-up: stap 3, afbeelding 1 van 2 How to Fix Broken Powder Make-up: stap 3, afbeelding 2 van 2
      • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
      Vraag FixBot
      Voeg opmerking toe
    4. How to Fix Broken Powder Make-up: stap 4, afbeelding 1 van 1
      • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
      Vraag FixBot
      Voeg opmerking toe
    5. How to Fix Broken Powder Make-up: stap 5, afbeelding 1 van 1
      • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
      • If the powder is not fully dry, let it sit for another hour and continue to check back.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
Meghan Smith
224 Reputatie
1 Handleiding geschreven
Cal Poly, Team 30-3, Green Spring 2015 Lid van Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Leden
38 handleidingen geschreven
1Gids Commentaar
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 45
Altijd: 2,456
