Ga door naar hoofdinhoud
How to Fix Anything
    1. How to Fix Anything, Define the Problem: stap 1, afbeelding 1 van 1
      • Try to describe what your device is doing and what instead you expect it to do.
      Vraag FixBot
      Voeg opmerking toe
      • If it is not obvious, check if the behaviour is actually a problem or not.
      • Pro tip: even if this is the intended behaviour, you are entitled to modify it, if you like. Just it's not "fixing" anymore: that's hacking!
      Vraag FixBot
      Voeg opmerking toe
      • Did you forget to put the plug in the socket? Did you check the battery? Is the light bulb burn out?
      Vraag FixBot
      Voeg opmerking toe
      • In Europe, everything has two years of warranty by law. Do not give up your rights!
      Vraag FixBot
      Voeg opmerking toe
      • There is a very good chance that you will find something useful with a little search online.
      Vraag FixBot
      Voeg opmerking toe
    2. How to Fix Anything, Talk to your Community: stap 6, afbeelding 1 van 1
      • Speak with friends, family or colleagues. Even if they don't know anything, speaking helps a lot the reasoning.
      • Speak to a rubber duck
      Vraag FixBot
      Voeg opmerking toe
    3. How to Fix Anything, Mind the safety.: stap 7, afbeelding 1 van 1
      • Take a minute to think if there is anything that could be a safety hazard.
      • Check the user manual and the package, if available, and the device itself for any danger label.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
You are now ready to repair your stuff!
29 andere personen hebben deze handleiding voltooid.
Davide
1.054 Reputatie
1 Handleiding geschreven
6Gids Commentaar
How to fix a 1998 fisher seph snow plow
Joseph427!@#$ - Antwoord Deel
Estaría bien que pusieran un traductor para poder leer los comentarios de la gente
Gracias
Ruiz Marga - Antwoord Deel
How to fix the spring in a Skoda Enyaq key fob.
Yvonne Pearson - Antwoord Deel
@yvonnepearson This video shows you how to do it.
VauWeh - Antwoord Deel
waxa aan ahay
Cabdi Cabdullahi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 292
Afgelopen 30 dagen: 850
Altijd: 12,878
