Ga door naar hoofdinhoud
How to Exit ZTE Max XL Field Test Mode
  1. How to Exit ZTE Max XL Field Test Mode, How to Exit ZTE Max XL Field Test Mode: stap 1, afbeelding 1 van 1
    • Field Test Mode (FTM) can be useful if you perform tests on signal strength, but for most users it prevents some applications to run correctly.
    • The phone screen will display FTM when in the mode.
  2. How to Exit ZTE Max XL Field Test Mode: stap 2, afbeelding 1 van 1
    • Hold down the power button for 10 seconds to turn off the phone.
  3. How to Exit ZTE Max XL Field Test Mode: stap 3, afbeelding 1 van 1
    • Press the power button until your phone responds to power on the phone.
    • To assure your phone does not stay in FTM, DO NOT press the lower volume button. Pressing of the lower volume button is the reason your phone enters FTM.
  4. How to Exit ZTE Max XL Field Test Mode: stap 4, afbeelding 1 van 2 How to Exit ZTE Max XL Field Test Mode: stap 4, afbeelding 2 van 2
    • If the phone is still in FTM after the reboot, make sure the lower volume button is not stuck.
    • After the button is unstuck, repeat step three.
Eindstreep
Olivia Wolf
1.400 Reputatie
5 handleidingen geschreven
UW Stout, Team S8-G2, Ogden Spring 2018 Lid van UW Stout, Team S8-G2, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G2
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 23
Altijd: 854
