Inleiding
Darn it! You've got a hole. Not to worry—fixing a hole in a knitted garment is easy. It just requires a needle, some thread, and a bit of patience.
Follow this step-by-step guide for basic instructions on darning. This process can be applied to any knitted garment from socks to sweaters.
Wat je nodig hebt
Inspect the damage. Clean any dirt or debris from the area.
Tie off any loose threads from the hole.
Pull the needle through to the front of the garment until the thread is taut and the knot catches in the back.
Take a single straight stitch going into a single layer of fabric and coming back up one row of the knit closer to the hole.
Stitch this second row the same way you did the first, but in the opposite direction. This time, go under the rows of knit you previously went over, and vice versa.
When you reach the end of this second row, turn around and continue stitching in the previous direction. Stitch rows back and forth until you have worked about a centimeter past the hole.
26 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
genuinely, thank you for the tutorial. appreciate it
A nicely done and illustrated set of instructions. I have been going the wrong way to mend. This will help me save a sweater I really like.
Thank you! Finally fixed a sweater I have had in back of my closet for months and it looks great. Your instructions were perfect!
nice, is it applicable to cotton T-shirts too?
