Inleiding
Clean the dispenser drawer, pump filter, door seal, and drum on a Beko front-loading washing machine to keep it clean and odor-free. This routine helps remove detergent residue, mold, and bacteria that can cause bad smells, especially if you mostly wash at 30 °C or 40 °C. The door seal is also called the door seal or door gasket. This guide was written using a Beko WN622W, but other Beko front-loading washers are similar and may have small control differences.
Wat je nodig hebt
Stap 1 Prepare the washer
Gather a brush, hot, soapy water, a wet cloth, a towel, a shallow container, and a washing machine cleaner.
Stap 2 Clean the pump filter
Clean the pump filter before working on the drawer and drum seal.
Remove the pump filter, clean away trapped debris, and reinstall it securely.
Stap 3 Remove the dispenser drawer
Pull the dispenser drawer out until it stops.
Press down the release button inside the drawer.
Pull the dispenser drawer out of the washer.
Stap 4 Clean the dispenser drawer
Scrub the drawer with a brush and hot, soapy water.
Remove mold, residue, and detergent residue from every compartment.
Keep cleaning until the drawer is clean and free of residue.
Stap 5 Clean the dispenser housing
Wipe the inside of the dispenser housing with a wet cloth and hot, soapy water.
Use a wire or a dental floss brush to clear the small jet holes if residue remains.
Slide the clean dispenser drawer back into the housing.
Stap 6 Clean the drum rubber
Open the door and wipe the door seal with the wet cloth and hot, soapy water.
Clean around the visible rubber until mold, residue, and residue are gone.
Stap 7 Add the cleaner to the drum
Pour one dose of washing machine cleaner straight into the drum.
If you don't have washing machine cleaner, add a small amount of normal liquid detergent or washing powder instead.
Stap 8 Select the cleaning program
Select Drum Clean or Service Wash if the washer has that program.
If it doesn't, select a cotton wash, set it to the hottest temperature available, and choose Quick Wash.
Press the Start button.
Stap 10 Finish and ventilate the washer
When the program ends, turn the washer off and open the door.
Check that the drum smells fresh.
Stap 11 Troubleshoot persistent odors
If the washer still smells after cleaning, check the pump filter and drainage hose for a blockage.
If the washer isn't draining water, clear the blocked drain before running another cleaning cycle.
Keep the door and dispenser drawer open after cleaning if the washer will sit unused, and repeat the routine every 30 cycles or every couple of months. If odors remain, check for a blocked pump filter or drainage hose before running another hot cleaning cycle. Repair didn't go as planned? Ask our Answers community for help.
