Ga door naar hoofdinhoud
How to Change Mercedes W123 Power Steering Fluid and Filter
Wat je nodig hebt
  1. How to Change Mercedes W123 Power Steering Fluid and Filter, How to Change Mercedes W123 Power Steering Fluid and Filter: stap 1, afbeelding 1 van 1
  2. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 2, afbeelding 1 van 3 How to Change Mercedes W123 Power Steering Fluid and Filter: stap 2, afbeelding 2 van 3 How to Change Mercedes W123 Power Steering Fluid and Filter: stap 2, afbeelding 3 van 3
  3. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 3, afbeelding 1 van 1
    • With the lid removed you can see that this fluid is a bit low, and is also very dark/dirty.
  4. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 4, afbeelding 1 van 2 How to Change Mercedes W123 Power Steering Fluid and Filter: stap 4, afbeelding 2 van 2
    • Remove the nut holding down the spring and plastic retainer, if present. On some cars, there is just a spring as shown in the second picture which should be removed.
    • The nut on this car is a 10mm.
  5. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 5, afbeelding 1 van 1
    • Now use your fluid extractor, or turkey baster (never use it in the kitchen again!) to remove enough fluid to get easy access to the filter.
    • Dispose of the fluid in your drain pan.
  6. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 6, afbeelding 1 van 1
    • Remove the filter using a pair of needle nose pliers.
  7. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 7, afbeelding 1 van 3 How to Change Mercedes W123 Power Steering Fluid and Filter: stap 7, afbeelding 2 van 3 How to Change Mercedes W123 Power Steering Fluid and Filter: stap 7, afbeelding 3 van 3
    • See how nasty this is? This may be the original filter, almost 30 years old...
    • Nice fresh filter picture, ready for install.
  8. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 8, afbeelding 1 van 1
    • With the filter out, you can remove the remainder of the fluid in the reservoir.
  9. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 9, afbeelding 1 van 1
    • Install your new filter. Install it with the holes facing upwards, as shown.
  10. How to Change Mercedes W123 Power Steering Fluid and Filter: stap 10, afbeelding 1 van 1
    • Replace the spring, retainer and nut over the filter and tighten down. The spring should still have some room to expand and contract but should be snug.
    • Fill the reservoir to the bottom of the metal rim around the top of the pump housing.
    • This car is getting power steering fluid, instead of automatic transmission fluid. Both are OK. The power steering fluid is clear.
    • Now, turn on the engine. Be sure the car is in park or neutral first. Turn the steering wheel left and right, as far as it will go, a few times to get out any air.
    • Top off the fluid as needed. Never let the pump run dry.
    • If your fluid is very dirty, simply repeat the process of sucking out fluid, putting the filter back in, filling the reservoir, and then running the engine and turning the wheel until it looks clean.
    Great job keep up the good work!
    cbelle1 - Antwoord
    Hallo, ich bräuchte die MB Teilenummer für die Deckeldichtung. Hat die hier jemand? :)
    Max VOGEL - Antwoord
    You really want to flush the fluid properly. Disconnect the return hose to the reservoir and have a friend run the engine. Collect the fluid now pumping out of the hose whilst you top up with clean fluid. When the hose runs out of dirty fluid and you see the colour of the new fluid, cut the engine. Top up to the correct level and the flush is complete.
    Chiswick Classics - Antwoord
Conclusie
Finish by re-installing the cap and taking it for a test drive.
21 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.040 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.532 handleidingen geschreven
14 opmerkingen
I find this tutorial so simple to follow. I prefer images and text to video. Well done!!!
Holden Belmont - Antwoord
Holden, I am glad it was helpful! I agree, I usually prefer good pictures and text to a video - no need to rewind when you miss something.
Nicolas Siemsen -
Agreed. Very well done !
susan vernon - Antwoord
Thank you so much for your detailed guides! What sort of symptoms could we expect if the power steering fluid or filter need replacing?
Angel Jon Camama - Antwoord
This was so professional; technical writers take notice!
Brian Graham - Antwoord
Good job plain and simple thank you
Mike - Antwoord
Question: Why do I need to jack up the car? Can't I just turn the wheels with the tires on the ground?
David Ballard - Antwoord
You could. However, turning the wheels while the car is on the ground and not moving puts substantial strain on the pump. If the front wheels are hanging freely in the air that is not an issue. Your pump, your car, your choice :) I would jack it up.
Nicolas Siemsen -
Beautifully explained and illustrated.
Thank You for helping our old cars on the road.
Terry Harris
thar1914 - Antwoord
How often should you ideally replace the fluid and filter? I’m guessing every other year…
Paul Alexander - Antwoord
On my old mustang I leave the low pressure hose off into a bottle and run the engine for a couple of seconds to drain the old PS oil in the system. New oil in the PS a pump reservoir, obviously. Can this be done on the ‘85 300D? I don’t see this hack on any of the forums? Thanks
albert scalla - Antwoord
How much oil do you need for a full change? Thank you
Ghita Andrei - Antwoord
Too bad this great ifixit is wrong. Just like any other W123/300D fluid change there is a proper DRAIN PLUG at the lowest point on this system on the bottom of the steering box! Put your drain pan under the steering box by the knuckle and the drain plug is right next to it. Remove the plug and it drains the whole system, lines, steering box and all...not just the reservoir. Replace the plug after you swap out filters and the whole system will have fresh MERCEDES steering fluid. Plug in and retightened refill then start diesel and swing from lock to lock to bleed.
Larry Butler - Antwoord
Thankyou so much !
You should have been a teacher 😜
Maybe you are you ,never the less ,Thankyou 🙏
I have a 1978 W123 250 straight 6 and wondering if the process is the same as what you have just explained with your model ?
Drayon Lowe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 152
Altijd: 24,786
