Inleiding
Learn to check the power steering fluid level on your Mercedes W123 to keep that boat turning smoothly!
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
Your power steering fluid reservoir is located within the pump which is on the right side of your engine, when facing it from the front of the car. In the U.S. this is the driver's side. Attached to it are the following components:
Pulley and belt
Hoses that connect to the steering box
Cover
To check the level of power steering fluid inside the pump's reservoir the cover will need to be removed.
With the cover removed you can now observe the fluid level.
The level should reach the small ledge at the back left of the reservoir.
While the cover is off you can also check the condition of the fluid by piping a small amount in to a syringe or turkey baster (used only for automotive fluids - never use it in the kitchen again!) If the fluid looks dark, instead of a clean red, consider changing it and the filter.
17 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
The indicator marker inside the pump reservoir is to measure fluid at hot (operating ) temperatures only. When cold or ambient the level should be between 6 and 8mm below that marker. The spring in this pump is missing the detent that holds it down. The spring is not meant to be held down by the reservoir cap.
Thanks a lot for sharing your knowledge and may God bless you. Take care.
