Inleiding
Every fixer should know their way around a multimeter, which has just north of a zillion uses for testing electronic components and circuits. Follow along to master the three most basic functions of a multimeter.
Wat je nodig hebt
A continuity test tells us whether two things are electrically connected: if something is continuous, an electric current can flow freely from one end to the other.
If there's no continuity, it means there is a break somewhere in the circuit. This could indicate anything from a blown fuse or bad solder joint to an incorrectly wired circuit.
The multimeter tests continuity by sending a little current through one probe, and checking whether the other probe receives it.
If the probes are connected—either by a continuous circuit, or by touching each other directly—the test current flows through. The screen displays a value of zero (or near zero), and the multimeter beeps. Continuity!
If the test current isn't detected, it means there's no continuity. The screen will display 1 or OL (open loop).
To complete your continuity test, place one probe at each end of the circuit or component you want to test.
As before, if your circuit is continuous, the screen displays a value of zero (or near zero), and the multimeter beeps.
If the screen displays 1 or OL (open loop), there's no continuity—that is, there's no path for electric current to flow from one probe to the other.
In this mode, the multimeter sends a little current through one probe, and measures what (if anything) is received by the other probe.
If the probes are connected—either by a continuous circuit, or by touching each other directly—the test current flows through. The screen displays a value of zero (or near zero—in this case, 0.8). Very low resistance is another way of saying that we have continuity.
If no current is detected, it means there's no continuity. The screen will display 1 or OL (open loop).
As before, if your circuit is continuous, the screen displays a value of zero (or near zero).
Plug the black probe into the COM port on your multimeter.
Plug the red probe into the VΩmA port.
Switch on your multimeter, and set the dial to DC voltage mode (indicated by a V with a straight line, or the symbol ⎓).
Most multimeters are not autoranging, meaning you will need to set the correct range for the voltage you expect to measure.
Each setting on the dial lists the maximum voltage it can measure. So for example, if you expect to measure more than 2 volts but less than 20, use the 20 volt setting.
If you're not sure, start with the highest setting.
Place the red probe on the positive terminal, and the black probe on the negative terminal.
If your range was set too high, you may not get a very accurate reading. Here the multimeter reads 9 volts. That's fine, but we can turn the dial to a lower range to get a better reading.
If you set the range too low, the multimeter simply reads 1 or OL, indicating that it is overloaded or out of range. This won't hurt the multimeter, but we need to set the dial to a higher range.
To begin, make sure no current is running through the circuit or component you want to test. Switch it off, unplug it from the wall, and remove any batteries.
Place one probe at each end of the circuit or component you want to test.
If your multimeter reads close to zero, the range is set too high for a good measurement. Turn the dial to a lower setting.
The other possibility is that the circuit or component you are testing doesn't have continuity—that is, it has infinite resistance. A non continuous circuit will always read 1 or OL on a resistance test.
1005 andere personen hebben deze handleiding voltooid.
132 opmerkingen
EASy and helpful indeed
Iwant to know hw to test caperstas
