Ga door naar hoofdinhoud
Hover-1 XLS Battery Replacement
Wat je nodig hebt
    1. Hover-1 XLS Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Hover-1 XLS Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Hover-1 XLS Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
      • There are four screws that need to remove. Two on one side and the two on the opposite side.
      Vraag FixBot
      Voeg opmerking toe
    2. Hover-1 XLS Battery Replacement: stap 2, afbeelding 1 van 3 Hover-1 XLS Battery Replacement: stap 2, afbeelding 2 van 3 Hover-1 XLS Battery Replacement: stap 2, afbeelding 3 van 3
      • Remove the adhesive holding the wires tightly.
      • You can use a sharp object to score the adhesive before pulling.
      • Pull on both sides of the wire connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jonathan Hidalgo
659 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G2, White Winter 2019 Lid van Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Leden
13 handleidingen geschreven
17Gids Commentaar
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - Antwoord Deel
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - Antwoord Deel
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - Antwoord Deel
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - Antwoord Deel
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 220
Altijd: 14,417
