Ga door naar hoofdinhoud
Hover-1 Superstar Battery Replacement
Wat je nodig hebt
  1. Hover-1 Superstar Battery Replacement, Bottom Case: stap 1, afbeelding 1 van 3 Hover-1 Superstar Battery Replacement, Bottom Case: stap 1, afbeelding 2 van 3 Hover-1 Superstar Battery Replacement, Bottom Case: stap 1, afbeelding 3 van 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
    Vraag FixBot
    Voeg opmerking toe
  2. Hover-1 Superstar Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
    Vraag FixBot
    Voeg opmerking toe
  3. Hover-1 Superstar Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Hover-1 Superstar Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Locate the four 14mm screws securing the battery bracket.
    • Remove the screws with a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Hover-1 Superstar Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull and disconnect the cable connector that is connected to the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Hover-1 Superstar Battery Replacement: stap 5, afbeelding 1 van 1
    • Pull on the battery until it separates from the hover board. You may need to use some force.
    • Be sure the battery is disconnected before performing this step to avoid electrocution.
    • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
    • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
1Gids Commentaar
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 2,379
