Ga door naar hoofdinhoud
Hover-1 Liberty Gyroscope Sensor Boards Replacement
Wat je nodig hebt
  1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    Vraag FixBot
    Voeg opmerking toe
  2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 2, afbeelding 1 van 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 2, afbeelding 2 van 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    Vraag FixBot
    Voeg opmerking toe
  3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 3, afbeelding 1 van 3 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 3, afbeelding 2 van 3 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 3, afbeelding 3 van 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  4. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: stap 4, afbeelding 1 van 1
    • Place the hoverboard so the sensor boards face you.
    Vraag FixBot
    Voeg opmerking toe
  5. Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 5, afbeelding 1 van 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 5, afbeelding 2 van 2
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
    Vraag FixBot
    Voeg opmerking toe
  6. Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 6, afbeelding 1 van 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 6, afbeelding 2 van 2
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
    Vraag FixBot
    Voeg opmerking toe
  7. Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 7, afbeelding 1 van 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 8, afbeelding 1 van 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: stap 8, afbeelding 2 van 2
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Eduardo Miranda
355 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G2, White Fall 2018 Lid van Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Leden
4 handleidingen geschreven
9Gids Commentaar
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - Antwoord Deel
Where do you get replacement board?
Tim Sole - Antwoord Deel
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - Antwoord Deel
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - Antwoord Deel
Where do you get circuit board from.
markrichardowen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 51
Altijd: 10,262
